Hi, I have a problem transferring the rating tags to the new computer, I tried to copy music from the Virtual Dj item and all I could transfer was the unrated colors. I copied the playlist from the virtual DJ bass but nothing helped. I will be grateful for help in this topic.
I'm using Virtual dj 2020
Jano
Jano
geposted Tue 14 Jan 20 @ 1:29 pm
Did you follow the instructions here? It explains what to copy over.
geposted Tue 14 Jan 20 @ 3:08 pm
Goto Settings>Options, search for and enable GetCuesFrom Tags
geposted Wed 15 Jan 20 @ 1:36 pm
Thanks for the help, but now a new problem has arisen. Windows 10 Professional 64 BIT has made an update and I can't turn on Virtual dj since. I did the installation of the old version of Virtual dj 8.2 and everything is OK, after updating the Virual dj to the new version the program stops working. I remind you that I'm using Denon DN-HC4500
geposted Mon 20 Jan 20 @ 10:37 am
I'm also having issues transferring music tag ratings from win 10 pc to mac OS. It's not an issue with VirtualDJ because I verified GetRatingFromTag option is enabled on both devices. I've tried multiple ways of copying music over and nothing works to transfer rating tag info. This was never an issue until the latter part of 2021, so something has changed either with win10 or OS. Does anyone have any clues here?
geposted Tue 11 Jan 22 @ 10:19 pm
I found a solution to this problem. For unknown reason, latest versions of VirtualDJ has an issue with showing all metadata after import. Most tags will be shown after import, suggesting it loaded tags correctly. No so. To get ratings and possibly other blank tags to show, right click on folder, run batch and reload tags.
geposted Wed 12 Jan 22 @ 12:50 am
