Small request. I'm sure it can be easily done. Can we have a command that we can use as a shortcut button on the keyobard to be able to change this setting: VideoWindowAlwaysOnTop? SO instead of going in the settings each time to change it, we could just hit a shortcut button.
geposted Tue 14 Jan 20 @ 6:16 pm
setting "VideoWindowAlwaysOnTop"
that's the script, that's how you change settings with script
geposted Tue 14 Jan 20 @ 6:20 pm
try it. it doesn't work.
geposted Tue 14 Jan 20 @ 6:49 pm
neither does the option when the video window is open, so do this
video & setting 'videoWindowAlwaysOnTop' & video
geposted Tue 14 Jan 20 @ 7:04 pm
I go this from facebook: var '$space' ? setting "videoWindowAlwaysOnTop" & video off & video on : video
so it works perfect.
geposted Wed 15 Jan 20 @ 4:57 am
if it was on facebook .... ^^
in addition to locodog's solution:
as the option applies only next time the window opens, doing this is also possible:
setting "videoWindowAlwaysOnTop" & video & video
i prefer this one as it immediately toggles the option whenever the video windows is initialy open or not
and it does not modify window status depending on a spurious global variable
geposted Wed 15 Jan 20 @ 6:53 am
