MY VIrtual dj8 got uninstalled from my laptop. Only my VDJ. As well, before the uninstall, the entire VDJ folder was backed up.No other music folders were touched. I reinstalled VDJ, and it installed fine. However, my harmonic Camelot keys are not listed, unlike before the uninstall...as well as my cues are missing. Instead, the keys column has default VDJ keys listed, NOT, the Camelots from Mixed In Key. Anyone have a suggested remedy?I am stumped. Is thee a specific folder i backed up that i should look for...and if so, what is it and where should it be? thnx for any aid.
geposted Sun 19 Jan 20 @ 1:41 am
...so the keys are NOT "missing" - they're just being displayed in musical rather than harmonic view.
You can change that, either via settings or (depending on skin) by simply clicking on the 'key' display of a loaded deck. It tells you this in the manual.
geposted Sun 19 Jan 20 @ 8:57 am
