Hi, Fam!
I have difficulties seeing which deck is Master Deck (Pro Layout), the light grey and dark grey that the word "MASTER" appears on screen don´t distinguish sufficiently for my old eyes.
Any Idea where in the skin (file?) I can change the color of the active "MASTER" indicator to something like amber/orange/yellow or red?
Thanks in advance,
Rattler
Thanks in advance,
Rattler
geposted Mon 20 Jan 20 @ 9:13 pm
Yes you can change the colorselected constant of the master deck buttons in the pro.xml file in the default skin to one of the other text color constants - like for instance:
colorselected="textbright"
You need to changes it in 4 places - one for each deck
That gives you this result
If that is not enough you can create your own constant in the top with each own color code - for instance a purple one (code: ff00ff) - and then use the new one in the 4 places
Then you get something like this:
geposted Mon 20 Jan 20 @ 9:38 pm
Thanks, bro, exactly what I was looking for!
geposted Tue 21 Jan 20 @ 4:01 pm
