Topic: [solved]drag playlists into folders.
In "Lists & Advice" > "Playlists", I right-click Playlists and select "Create sub-folder". I try to drag an existing playlist into the folder, but it lands below the folder, not in the folder.
I can right-click the folder and select "Create new playlist" and then rename it and then click the playlist I was trying to move and then select all and then drag the files into the new playlist and then delete the source playlist. When you're trying to move 100 playlists into folders, that's a lot of work.
Is there a faster way?
*Why can't we drag playlists into playlist folders?*
(Using the latest Virtual DJ: v8.4 b5784)
geposted Fri 24 Jan 20 @ 12:35 pm
Make sure when you drag that the red line is directly under the folder icon. [so keep your cursor on, but to left part of the folder icon.
geposted Fri 24 Jan 20 @ 12:56 pm
Thank you @locodog!
I was seeing the red line when I tried before, but I never shifted my mouse so the red line moved to the left.
That's actually counterintuitive. Moving it to the left should move it in line with other top-level entries (folders, playlists), whereas if the line is to the right, that makes it in line with sub-entries.
geposted Thu 06 Feb 20 @ 8:54 pm
