I had "the world's best-organized music library" - in MediaMonkey. Then I got married, and I wanted my wife and I to be able to play music from each other's collections, and since she only knew iTunes, I migrated everything to iTunes. All my ratings were lost. iTunes uses a different ratings [format] / database field name than Windows Explorer / Media Monkey. Now I'm in Virtual DJ, and it's not showing ratings from songs that show ratings in iTunes and/or Windows Explorer.
Do I need to re-rate all my music?
geposted Fri 24 Jan 20 @ 1:19 pm
Right-click the iTunes folder and select 'import ratings'
geposted Fri 24 Jan 20 @ 1:35 pm
Thank you!
Can I do the same for songs rated in MediaMonkey / Windows Explorer but not rated in iTunes?
I right-clicked "Local Music" etc, but found nothing like "Import Ratings".
geposted Fri 24 Jan 20 @ 7:31 pm
Windows Media Player and Windows Explorer store the ratings in the tag of the file I think.
Make sure getRatingsFromTags option is enabled, and then right-click the files you want to update and select Reload Tags.
geposted Fri 24 Jan 20 @ 7:33 pm
Thanks @Adion!
geposted Thu 06 Feb 20 @ 9:10 pm
