What does the Command Script QuantizeAll ?
geposted Fri 31 Jan 20 @ 11:56 pm
I just noticed that myself, likely, smart cue, smart play, quantize loop, quantize set cue, all that stuff.
geposted Sat 01 Feb 20 @ 12:26 am
I thought the same.
But I tried this command.
This has not switched any of these commands on or off.
The commands like SmartCue, SmartLooop, QuantizeSetCue ect. can only be switched off individually using a button.
The Command QuantizeAll , does nothing.
I dont know what it Do.
geposted Sat 01 Feb 20 @ 2:20 am
try using "quantize_all"
should turn them all on or off
geposted Sat 01 Feb 20 @ 2:27 am
No , this is because I post this Topic.
The Command does nothing at all , it turn not the SmartCue , QuantizeSetCue or this off or on.
This Command does nothing ;-)
And unfortunately there is again no description of this command.
I just want to know what it does ..
geposted Sat 01 Feb 20 @ 3:06 am
It turns on quantize all .. (cue, loop, play )
(when turned off, it remembers prior settings, if you already had set "smart"/quantize cue. loop etc on individually.. these works independently )
And just test it, works great ;-)
geposted Sat 01 Feb 20 @ 7:26 am
By Me it turnes nothing from this Settings on or off ....
Quantize_all dooes nothing.
Only this Command on my Button turn all this on or of :-)
deck 1 smart_cue ? deck all smart_cue off & smart_loop off & quantize_loop off & quantize_setcue off & cue_loop_autosync off : deck all smart_cue on & smart_loop on & quantize_loop on & quantize_setcue on & cue_loop_autosync on
geposted Sat 01 Feb 20 @ 5:57 pm
It will not change any of these options, it will override them.
So if quantize_all is on, you should see the deck quantizing, even if smartplay etc... is off
geposted Sat 01 Feb 20 @ 6:03 pm
I don't really understand.
So these settings like Smart_Cue ect. are not turned on with it?
But should everything be quantized as if it were on?
Please show me an example.
geposted Sat 01 Feb 20 @ 6:11 pm
Correct.
As an example, enable quantize_all, then press play and it will be synced
geposted Sat 01 Feb 20 @ 6:34 pm
Adion wrote :
Correct.
Ok, but you won't see the Smart_Cue and Smart_Loop that they are set to YES in the options?
But does Quantize_all quantize the loops and cues?
The command is also only quantize_all, and it is switched on by pressing, and switched off when pressed a second time?
I mapped the command above to my Quantize button on the controller, but without Smart_play, because I don't always want to use that. (deck 1 smart_cue? deck all smart_cue off & smart_loop off & quantize_loop off & quantize_setcue off & cue_loop_autosync off: deck all smart_cue on & smart_loop on & quantize_loop on & quantize_setcue on & cue_loop_autosync on).
Now I had simply tried the quantize_all command on the same key when I pressed Shift. I wanted to test it.
But saw nothing.
geposted Sat 01 Feb 20 @ 6:51 pm
Correct
Quote :
Yes
Quote :
Correct
geposted Sat 01 Feb 20 @ 7:55 pm
I will test it further.
But so far I don't really see any results when I press it and turn it on.
geposted Sat 01 Feb 20 @ 8:15 pm
Gave it a try here to check and works as I said.
To try I disabled smartplay, then enabled quantize_all, and then press play and it's still synced.
geposted Sat 01 Feb 20 @ 8:29 pm
in settings , globalquantize 0 ?
geposted Fri 14 Aug 20 @ 1:22 am
