Topic: New Laptop
Hi there,
I've recently gotten back into DJing, i previously bought a Numark N4, however i've updated my laptop (windows) and have lost the disc that downloaded the software that worked with the deck. How can i use my deck and connect with virtual DJ?
Thanks
geposted Sat 01 Feb 20 @ 10:30 pm
PhilWPRO InfinityMember since 2011
What software are you looking for? According to the VDJ hardware manual for the N4 (https://www.virtualdj.com/manuals/hardware/numark/n4.html), no drivers are required.
Numark's page (https://www.numark.com/product/n4) also doesn't show any required software. It does, however, list Asio4All which I would recommend against installing as it just adds an ASIO interface to regular Windows sound devices without improving latency. WASAPI should give you low latency without any additional drivers.
geposted Mon 03 Feb 20 @ 1:25 pm
