Hey everyone,
I'm using a DDJ1000 and i want to use the SAMPLER_VOL param to modify the resonance of the colorfx filter. I tried setting
SAMPLER_VOL filter_resonance
but to no avail, i'm guessing because there's a difference between the normal filter and the colorfx one.
Would anyone know how one would go about doing this?
Thanks
Thanks
geposted Sun 02 Feb 20 @ 12:23 pm
1) colorfx are a little different from effects in slots and seems to be usable only when selected
2) "Resonance" is the second slider of effect 'filter'
3) filter_resonance is a specific verb for colorfx and may or not work with effect 'filter' (slider update issue)
filter_selectcolorfx 'filter' & effect_slider 'colorfx' 2
should work but the bug in parameters prevents custom slider from update - i don't know with mapper
filter_selectcolorfx 'filter' && effect_slider 'colorfx' 2
is ok
as usual there are many ways to acheive what you want
mapping SAMPLER_VOL to:
work fine but force filter as a colorfx
filter_selectcolorfx 'filter' ? effect_slider 'colorfx' 2
will only work when colorfx 'filter' is selected
if you want to modify other specific parameters depending on selected effect yo may use thing like this (resonance for filter / feedback for flanger)
filter_selectcolorfx 'filter' ? effect_slider 'colorfx' 2 : filter_selectcolorfx 'flanger' ? effect_slider 'colorfx' 3
is ok
geposted Sun 02 Feb 20 @ 2:23 pm
Hey sorry for the month late response. I just tested and
works just fine, and it doesn't change the colorfx when you move it
geposted Mon 16 Mar 20 @ 5:12 pm
