Can anybody explain how I can configure a 'Custom Button' so when clicked will display the 'Info Tab' of the CURRENT playing song - (NOT the browsed song). Have spent many hours trying to achieve this.
geposted Mon 03 Feb 20 @ 4:41 pm
Info tab is always browsed song.
you could use
file_info
and use Esc to exit
you could use
file_info
and use Esc to exit
geposted Mon 03 Feb 20 @ 5:05 pm
Or... You could build your own info panel and open it with a custom button.
geposted Mon 03 Feb 20 @ 10:04 pm
or use a custom button with this script ...
of course first including FileName as a search field
search `get_filename` & show_splitpanel info ? nothing : show_splitpanel info.
geposted Mon 03 Feb 20 @ 10:17 pm
