Topic: Distortion on samples
MellpotPRO InfinityMember since 2013
Anybody else having this little problem win10 latest build VDJ 2020 64bit i5 buffer 512 dell laptop when selecting installed sample kick snare or other kick samples pressing the pitch + key the sample starts to crack with the beat as it speeds up.
Not a big problem but after spending a few hours i gave up trying to fix it any ideas ?
geposted Tue 04 Feb 20 @ 12:24 am
Forgot to mention same fault on 2 different systems 1 using Denon MC 6000 mk2 and the other a Denon MC 7000 both running 64 VDJ
geposted Tue 04 Feb 20 @ 12:27 am
sampler keyfx is live and on the fly key transforming so it takes a lot of processing, my machine struggles with it too
geposted Tue 04 Feb 20 @ 1:09 am
Should not be too cpu intensive, but the quality is indeed not as good as changing key on decks yet.
To check if it is because of cpu you could check the cpu meter tooltip (peak audio in particular) or see if a song playing on deck is also affected.
geposted Tue 04 Feb 20 @ 7:52 am
