Topic: Reverse latest update?
tomsy75PRO InfinityMember since 2012
Since updating to latest version the fx on my Denon MC4000 no longer work correctly.
Is there a way to revert back to a previous version?
geposted Fri 07 Feb 20 @ 7:33 pm
geposted Fri 07 Feb 20 @ 8:35 pm
Thanks - only seems to support w10 not 7 tho :(
geposted Sat 15 Feb 20 @ 7:13 pm
get the 32 bit version
geposted Sat 15 Feb 20 @ 7:15 pm
thanks - still hasnt solved the fx issue... :(
geposted Sat 29 Feb 20 @ 5:23 pm
Perhaps if you expanded a bit on "no longer work correctly"....
geposted Sat 29 Feb 20 @ 6:17 pm
