Hey guys and gals
im connected to an MC6000
hp laptop
windows 10 I believe
Ive been a pro subscriber for years
ive always been able to figure out the bugs pretty quick. This has me stumped and I have a party tomorrow night
my software fader and controller fader have never worked in unisen but that never mattered to me
now my crossfader starts in my softer to the left or right, playback from both decks no matter what I do. then to make it worse i downloaded VDJ again and have two icons on the desktop buy only one VDJ in my installed progtams.
I dont even know wher to start at this point
inputs are
master 1 and 2
headphones 3 and 4
deck 1 1 and 2
deck 2 3 and 4
controller set to pc. pc mix stereo master record
URGENT!!!!
hp laptop
inputs are
master 1 and 2
headphones 3 and 4
deck 1 1 and 2
deck 2 3 and 4
URGENT!!!!
geposted Sat 08 Feb 20 @ 12:59 am
Why do you have deck outputs & master output? surely you need one or the other, not both.
Also check your front panel xf assign switches
geposted Sat 08 Feb 20 @ 1:10 am
it has always been set this way and worked flawless well an update if i set crossfader to full it works but cant be used that way i just want to go back to the previous build but cant find the link
this new update has totally taken over my controller and i dont like it
It sounds like shit, very little audio adjustment and horribl sound
geposted Sat 08 Feb 20 @ 1:26 am
geposted Sat 08 Feb 20 @ 1:56 am
WTF
reverted to last build same outcome
trying back up Laptop
geposted Sat 08 Feb 20 @ 1:57 am
well went back to a previous build same results
tried back up pc same results
the fader in the software works correctly but on my controller it doesnt
when i go in settings for the crossfader i can move the fader on the controller and the values are correct.
anybody?
anybody?
geposted Sat 08 Feb 20 @ 2:41 am
You might want to try the setup you find here
https://www.virtualdj.com/manuals/hardware/denon/mc6000/setup.html
geposted Sat 08 Feb 20 @ 3:08 am
