scenario: some buttons on my skin have two functions(for example...the filter button is mapped to color fx and when i right click it acts as a slider control for a vst)
where shift Filter activates the 2nd function.
is there a way for the skin to automatically switch to display which of the two actions are being performed?(without manually right clicking on the filter on the skin).
so basically when i hit shift filter..the skin auto changes from the color fx slider to the vst slider and reverts when i just use filter without the shift.
custom buttons on skins could also work this way..but this maybe more complex
geposted Wed 12 Feb 20 @ 1:12 am
Yeah it probably could be done, visibility tied to shift or perhaps is_using
geposted Wed 12 Feb 20 @ 1:44 am
Ok..im not as verse in editing the skin xml..but will do some investigations
geposted Wed 12 Feb 20 @ 3:16 am
Take a look at the 3fx panel that does the same kind of thing.
geposted Wed 12 Feb 20 @ 4:28 am
Quick way:
1) Locate the elements you want to change.
e.g.
<button class="bla" .....>
</button>
<slider class="bla2"....>
</slider>
2) Make a panel for normal behavior and move those elements inside it
<panel name="NotShift" visible="not shift">
</button>
</slider>
</panel>
3) Make a copy of that panel, and change visible query and the actions of the elements
<panel name="WithShift" visible="shift">
</button>
</slider>
</panel>
In other words you should end up with this:
</button>
</slider>
</panel>
</button>
</slider>
</panel>
e.g.
</button>
</slider>
</button>
</slider>
</panel>
</button>
</slider>
</panel>
</button>
</slider>
</panel>
</button>
</slider>
</panel>
geposted Wed 12 Feb 20 @ 9:19 am
Will give it a go..thanks again
geposted Wed 12 Feb 20 @ 12:46 pm
