Hi, just wonder where I can adjust the parameters for DDJ-1000 fx buttons D.ECHO, PITCH, NOISE, FILTER.
For example I want to adjust the volume level of the noise fx.
I could live with one setting that is written ONINIT or similair.
geposted Wed 12 Feb 20 @ 9:21 pm
You can't.
These are "color effects" and color effects are designed to have only one parameter (like dry/wet or strength e.t.c.) centered in the middle (off)
geposted Thu 13 Feb 20 @ 1:54 pm
That makes the noise effect basically unusable for me because the volume level of that is way to high to be used...
Thanks for letting me know.
geposted Thu 13 Feb 20 @ 2:42 pm
PhantomDeejay wrote :
You can't.
What? These gui, and .ini's like native_noise_1 completely disagree.
filter_selectcolorfx 'echo' & effect_show_gui 'colorfx' &
filter_selectcolorfx 'filter' & effect_show_gui 'colorfx' &
filter_selectcolorfx 'noise' & effect_show_gui 'colorfx'
Setting with oninint is awkward but noise color fx can certainly be turned to a lower or higher W/D and it can be saved in the ini
geposted Thu 13 Feb 20 @ 11:22 pm
