I'm looking at the native fx .ini files and I'm seeing something I don't understand
native_FXNAME.ini
that's just as I understand
native_FXNAME_1.ini
I think this is the ini for colorfx
but I'm also seeing numbers 2,3,5,6,7,8
I'm trying to figure out what we have here
guessing there's one for each of these, but I'm guessing
AOV
master
autostart
sampler
other?
native_FXNAME.ini
native_FXNAME_1.ini
AOV
master
autostart
sampler
other?
geposted Fri 14 Feb 20 @ 1:13 am
0=Transition
1=Video FX
3=Audio Only Visualisation
5-8=ColorFX1-4 (3 used by starter skin)
9=ReleaseFX
10=MixFX
1=Video FX
9=ReleaseFX
10=MixFX
geposted Fri 14 Feb 20 @ 4:46 am
And what is 1 ?
Normal Decks are without numbers.
geposted Sun 11 Oct 20 @ 3:58 am
1=ColorFx
geposted Sun 11 Oct 20 @ 7:03 am
Ahh ok.
I think You say its 4-7 ?
geposted Sun 11 Oct 20 @ 8:52 am
The 'normal' color fx that replaces the filter is 1, but the effects on the basic skin are actually 3 different color fx slots which get numbers 4-7
geposted Sun 11 Oct 20 @ 9:37 am
Basic Skin?
You mean the Starter or Essencials Skin?
geposted Sun 11 Oct 20 @ 9:53 am
4, 5, 6, 7 - that's four numbers, Adion.
geposted Sun 11 Oct 20 @ 9:57 am
Ok , i have seen now .
But it make 5 6 and 7 ... 4 is not there ;-)
geposted Sun 11 Oct 20 @ 10:04 am
Sorry, updated the original answer with the correct numbers.
There are 4 separate color fx slots available, but indeed only 3 used by the starter skin.
geposted Sun 11 Oct 20 @ 10:28 am
