So I recently switched to the Denon MC 7000 and I can't script the Play/Pause button to stop doing a brake stop like vinyl. When I hit the pause button I want it to come to an immediate stop. I've changed all the setting to play_pause but it keeps happening.
Where would the setting be to get rid of the slow brake and pause the track right where I hit it?
geposted Sat 15 Feb 20 @ 11:48 pm
search options for "rampStop"
geposted Sun 16 Feb 20 @ 12:11 am
Ramp Stop and Start are both set to 0.000000
What should they be if I want it to suddenly stop and not brake?
I reset to factory defaults and noticed on mapping that Play is assigned to controllers and pioneer_play. I've mapped it to audio_controls and play_pause again. And under Options playmode is set to play-pause. It's still a slow brake.
geposted Sun 16 Feb 20 @ 12:26 am
Thanks for the help but I just figured it out.
Denon thought they'd be cute and make it an actual rotary knob just above the jog wheel.
Thanks again. Gonna be a big learning curve for this one for some reason.
geposted Sun 16 Feb 20 @ 12:34 am
buenas me ayudan tengo problemas con mi denon 7000 en el modo vinyl no funciona simulando turntable gracias
geposted Mon 02 Mar 20 @ 5:58 am
