Looking for a script to toggle between Custom buttons, Hot cues and hot cues(5-8) only on the user panel. Intend to use the keyboard shortcut for the active deck.
Thank you.
Thank you.
geposted Sun 16 Feb 20 @ 4:23 am
First select/mark only the ones you want to switch between, and then map:
skin_panelgroup 'custom_deck1' +1
and
skin_panelgroup 'custom_deck2' +1
... and the same for deck 3 and 4 if you need it
and
geposted Sun 16 Feb 20 @ 8:34 am
double post
geposted Sun 16 Feb 20 @ 8:36 am
@ klausmogensen thanks
geposted Sun 16 Feb 20 @ 1:03 pm
@lincol2 , the eye dropper on the mapping window would have found it for you
geposted Sun 16 Feb 20 @ 1:08 pm
Brother please excuse my ignorance, where is the mapping window for these Panel and how do I get to it and what/where is the eye dropper? Can someone do a video on it? I'm sure many users would love to know and use this knowledge..
Please.
geposted Sun 16 Feb 20 @ 2:07 pm
it's just a tip to easily get the related action not looking for it for hours reading the skin ^^
Mapping Window : settings-> Controllers
"eye dropper" : the color picker looking icon at bottom center near list of actions
this enable you to get the action in action area just by selecting the skin element directly on the skin using the "eye looking" mouse cursor
you do not have to alter the mapping at exit
may or may not work depending on skin elements overlapping / masks, no problem with default skins
geposted Sun 16 Feb 20 @ 2:27 pm
the usual keyboard mapping window
geposted Sun 16 Feb 20 @ 2:58 pm
@Nicotux thank you for the information.
I will just settle with the script from klausmogensen.
Thanks guys
Thanks guys
geposted Sun 16 Feb 20 @ 11:01 pm
