Hello,
I have updated today to 5522.
When I have started VDJ animated elements were flickering as seen on the following picture:
I have installed a backroll to 5504, this build is working fine.
Due to this was an early access build i thought it would be nice to know what the Update does.
System Information:
Lenovo YOGA 510-15IKB
Intel Core i5 7200U @ 2,5 GHz
DDR4 16 GB RAM
Intel HD Graphics 620 / AMD Radeon R7 M360
System Information:
DDR4 16 GB RAM
geposted Sun 16 Feb 20 @ 7:15 pm
BUILD 5522 (2020-02-06)
-Pioneer XDJ-XZ support
-stopwatch and stopwatch_reset actions
-param_cast "absolute" and param_cast "relative"
-fix default cue point names not shown when get_text or format= is used
-fix load_next after load_previous not ending up on same song
-Colored waveform overview in dialogs
-Fix swap_decks not swapping video
-Fix effect_active "sampler" "effectname" requiring effectname to be selected in slot as well
geposted Sun 16 Feb 20 @ 7:39 pm
