Hello, does anybody have an xml script to use the "reverse/direction" rocker switch on on CDJs to switch between decks 1-3 and 2-4 with a single up/down motion?
geposted Mon 17 Feb 20 @ 11:59 am
I figured it out!!! It turns out it was really simple. No need to use variables. Just type this line under "Reverse" to use "Direction" switch on CDJ 2000 xxx to switch decks 1-3 and 2-4 with 2 controllers.
down ? invert_deck : invert_deck
If you want to us one of the other push buttons, no need to to use any other fancy script, simply use the line below.
invert_deck
invert_deck
geposted Wed 04 Mar 20 @ 12:53 pm
