DeeJay MAE wrote :
Hello All, I own a DDJ-RZX too and I am so happy with it. I have no screen issues, I have only the output issue that cut off randomly. But I did a workaround yesterday at home and would like to share it with you. I've used an external sound card and configure it as a second master output beside the RZX master in the audio section (but be sure to use the RZX in internal mode), so now I have two stereo outputs, 1st going from RZX to the main PA mixer, the 2nd from external sound card to the main PA mixer, if something happened with the RZX output I will switch directly to the other by increasing its own volume, but I think I risk losing the PFL function on the RZX, am I right ??? I have no answer to this because I tried to play nearly three hours waiting for the output issue to happen so I can test my workaround, but sadly when I needed it to happen it didn't HAHA. Your feedback is welcomed.
I also had no screen issue but have sorted it with changing my firewall setting
geposted Sat 01 Aug 20 @ 1:40 pm
