Hi, I just bought a Numark party mix and have downloaded virtual DJ. I don't have wired speakers and can't seem to get the output to play through my Mac book pro or Sonos bluetooth speaker. Was wondering if anyone knows a way to do this?
Thanks for your help
geposted Fri 21 Feb 20 @ 7:05 pm
if you are using virtual dj LE i am sure it only works with the default audio config for the decks it came with
geposted Fri 21 Feb 20 @ 8:02 pm
I think you can use your machine soundcard as master, leave your headphone out as the pmix
geposted Fri 21 Feb 20 @ 8:09 pm
Even if you could get a Bluetooth speaker to work, the latency (delay between an action and when the sound comes out of the speaker) would make mixing much more difficult.
geposted Sun 23 Feb 20 @ 3:20 pm
