Please can I get a help of this action,'
Play_shutter for the selected deck and cue_stop for the opposite deck.
Thanks.
Thanks.
geposted Sun 23 Feb 20 @ 1:12 am
in this case cue_stop needs the deck to be specified before it, to know what the opposite deck is you need to know what the selected deck is
deck 1 select ?
that will tell you if deck 1 is selected, after that it should be easy.
deck 1 select ?
geposted Sun 23 Feb 20 @ 2:34 am
Please I have set my left and right arrow key like; load & hot cue 1.
And use v key like play stutter & deck active cue stop.
After using v key and want to load the previous active deck, it set different cue 1 and doesn't play until I reopen the software again.
Please do that action for me I want to play the unmastered or the selected and stop the opposite or the master deck immediately I press.
Thanks
Thanks
geposted Tue 25 Feb 20 @ 11:34 pm
You keep asking but show no signs of learning, so I'm not going to spoon feed you the answer.
You haven't even shown what you have attempted.
Seriously all the info you need is in my previous post, try use it, you'll learn something.
geposted Tue 25 Feb 20 @ 11:56 pm
