0kay, so I have held off for quite some time and stayed on VDJ version 7. Recently I switched to the latest version. Since then I have had to change a few things in my VDJScript controller mapping to get things to work with the new version of VDJ.
I had some help here before Scripting out some of what I wanted to accomplish which is why I'm having a little trouble fixing it.
I have the Hercules RMX.. it has 6 , lets say "effect buttons" ...I have each button (using a specific skin) assigned to a specific effect.
what I had help with scripting was making those "effect buttons" control the assigned effects silders using the jogwheel while the effect button was held down..left jog controlled slider 1 and right controlled slider 2.
Everyything worked great on version 7. But on the latest version, the VDJScript that I have currently has a flaw.. regardless of which of the 6 effect button are held, the jog wheel only moves the slider for the effect in slot one... how do I fix it where I can hold , say effect button 3, move the left or right jog and it control the slider for effect slot 3 rather than just slot one..?
Here is what I have scripted...
Jog:
((Again, I realize that the "var $passtek ? deck 1 effect "pass_texzk_old" slider 1" is now obsolete, I just haven't omitted it yet))
Who can help me out, please and thank you!
Button1 = effect 1 active
Button2 = effect 2 active while_pressed & action_deck 1 ? set $d1effect while_pressed : set $d2effect while_pressed
Button3 = effect 3 active while_pressed & action_deck 1 ? set $d1effect while_pressed : set $d2effect while_pressed
Button4 = effect 4 active while_pressed & action_deck 1 ? set $d1effect while_pressed : set $d2effect while_pressed
Button5 = effect "Pass_TexZK_old" active ((I realize this effect doesn't exist in the new version, I just haven't reassigned it yet))
Button6 = effect 6 active while_pressed & action_deck 1 ? set $d1effect while_pressed : set $d2effect while_pressed
Jog:
var $passtek ? deck 1 effect "pass_texzk_old" slider 1 : var $d1effect ? action_deck 1 ? deck 1 effect default slider 1 : deck 1 effect default slider 2 : var $d2effect ? action_deck 2 ? deck 2 effect default slider 2 : deck 2 effect default slider 1 : jog_wheel
geposted Sun 23 Feb 20 @ 4:04 am
A couple of changes between v7 & v8 syntax, I'm not sure where backwards compatibility breaks down as I've forgotten the v7 stuff
effect_active "NAME"|slot number
effect_slider "NAME"|slot number, slider number
That should have you going again
geposted Sun 23 Feb 20 @ 5:17 am
So it should look like...
Jog:
var $d1effect ? action_deck 1 ? deck 1 effect_slider 1 default : deck 1 effect_slider 2 default : var $d2effect ? action_deck 2 ? deck 2 effect_slider 2 default : deck 2 effect_slider 1 default : jog_wheel
#OverMyHead lol
geposted Sun 23 Feb 20 @ 6:48 am
I think this is what you want, say if not.
var $d1effect ? action_deck 1 ? deck 1 effect_slider 1 1 : deck 1 effect_slider 1 2 : var $d2effect ? action_deck 2 ? deck 2 effect_slider 1 2 : deck 2 effect_slider 1 1 : jog_wheel
deck 2 effect_slider 1 2 = slot 1, slider 2
geposted Sun 23 Feb 20 @ 7:16 am
that still only moves slider 1 & 2 in effect slot one..
i need it to control the sliders 1 & 2 of the effect currently active rather than being bound to a specific effect slot
geposted Sun 23 Feb 20 @ 9:16 am
should I individualize each button variable rather than using a single variable for all 6 buttons?
instead of
do something like..
Button2
and then just duplicate the jog code and change out each variable???
would be alot of code under jog....idk
instead of
do something like..
Button2
set $d1effect2 while_pressed
geposted Sun 23 Feb 20 @ 9:30 am
that would do it, and trust me that's not a lot of code.
geposted Sun 23 Feb 20 @ 9:51 am
Would this do?
Buttons:
and
Jog:
Buttons:
Button1 = effect 1 active while_pressed & action_deck 1 ? set $d1effect1 while_pressed : set $d2effect1 while_pressed
Button2 = effect 2 active while_pressed & action_deck 1 ? set $d1effect2 while_pressed : set $d2effect2 while_pressed
Button3 = effect 3 active while_pressed & action_deck 1 ? set $d1effect3 while_pressed : set $d2effect3 while_pressed
Button4 = effect 4 active while_pressed & action_deck 1 ? set $d1effect4 while_pressed : set $d2effect4 while_pressed
Button5 = effect 5 active while_pressed & action_deck 1 ? set $d1effect5 while_pressed : set $d2effect5 while_pressed
Button6 = effect 6 active while_pressed & action_deck 1 ? set $d1effect6 while_pressed : set $d2effect6 while_pressed
and
Jog:
var $d1effect1 ? action_deck 1 ? deck 1 effect_slider 1 1 : deck 1 effect_slider 1 2 : var $d2effect1 ? action_deck 2 ? deck 2 effect_slider 1 2 : deck 2 effect_slider 1 1 : var $d1effect2 ? action_deck 1 ? deck 1 effect_slider 2 1 : deck 1 effect_slider 2 2 : var $d2effect2 ? action_deck 2 ? deck 2 effect_slider 2 2 : deck 2 effect_slider 2 1 : var $d1effect3 ? action_deck 1 ? deck 1 effect_slider 3 1 : deck 1 effect_slider 3 2 : var $d2effect3 ? action_deck 2 ? deck 2 effect_slider 3 2 : deck 2 effect_slider 3 1 : var $d1effect4 ? action_deck 1 ? deck 1 effect_slider 4 1 : deck 1 effect_slider 4 2 : var $d2effect4 ? action_deck 2 ? deck 2 effect_slider 4 2 : deck 2 effect_slider 4 1 : var $d1effect5 ? action_deck 1 ? deck 1 effect_slider 5 1 : deck 1 effect_slider 5 2 : var $d2effect5 ? action_deck 2 ? deck 2 effect_slider 5 2 : deck 2 effect_slider 5 1 : var $d1effect6 ? action_deck 1 ? deck 1 effect_slider 6 1 : deck 1 effect_slider 6 2 : var $d2effect6 ? action_deck 2 ? deck 2 effect_slider 6 2 : deck 2 effect_slider 6 1 : jog_wheel
geposted Sun 23 Feb 20 @ 8:22 pm
I just got a chance to test that...
That seems to output my desired results...
Thank you for guiding me to a solution!!!
geposted Sun 23 Feb 20 @ 9:36 pm
Can someone point me how I can turn the view button on a mixtrack pro to switch between cues. ie I have 3 buttons.hotcue 1..hotcue 2 and hotcue 3 …I want to get the view button to switch these buttons to hotcue 4.5 and 6 if you understand what I mean , any help or pointers much appreciated
geposted Sat 21 May 22 @ 2:12 pm
to me it looks like the view button is used as a sw shift, but only for deleting cues
so something like this
button named shift
toggle hcLevel
LED_SHIFT
var hcLevel
hot_cue_1
var hcLevel ? hot_cue 4 : hot_cue 1
LED_hot_cue_1
if view is lit up you're looking at 4,5,6 cues
button named shift
toggle hcLevel
LED_SHIFT
var hcLevel
hot_cue_1
LED_hot_cue_1
geposted Sat 21 May 22 @ 2:41 pm
Thanks just trying to work it out, thanks for your help
geposted Sat 21 May 22 @ 3:29 pm
Your a genius ..thanks again, saved me having to upgrade and pay £50 for a Mixtrack pro 2
geposted Sun 22 May 22 @ 10:40 am
A bit more help if possible, 4 buttons manual..in..out and reloop, how can i map them just to play a loop length when selected.. please
geposted Sun 22 May 22 @ 11:08 am
look up the description, in the mapping section, for
loop
loop
geposted Sun 22 May 22 @ 11:30 am
