Good day VDJ world! I finally got around to recording from my NS7 lll after the update to VDJ and find that my volume output on the recording is way too low. When I raise the gain on VDJ, I clip which cause distortion as we all know. I also tried using my output into my DAW and found myself raising the volume on my interface. I haven’t tinkered with all the new settings yet and I haven’t found information on this here or maybe I am not typing the right “search” in the forums to see if this problem has been resolved. TIA.
geposted Mon 24 Feb 20 @ 11:21 am
Do you have a "record" line in your VirtualDJ Audio Setup, or just "master" and "headphones" lines ? If yes, can you try without it ? Wont include the MIC inputs probably, but curious to know the result.
How is your recording if not using the NS73 ?
geposted Mon 24 Feb 20 @ 1:00 pm
Hmm. I do have a record line.
geposted Tue 25 Feb 20 @ 1:10 am
I have a DDJ SX2 that was working flawlessly. Picked up an NS7 3 because of the platters. Wanted to get a mixtape in but took too long to get right that I quit for the night.
geposted Tue 25 Feb 20 @ 1:18 am
