Will the new vdj 2020 work with my controller..the mc6000?
geposted Tue 25 Feb 20 @ 1:28 am
geposted Tue 25 Feb 20 @ 1:48 am
Yes, but, you need a license for more than 10 minutes of use.
Also, you can't use Denon's ASIO driver on Windows if you use a PC, you must use WASAPI drivers.
geposted Tue 25 Feb 20 @ 11:05 am
I have a Mc6000 mk2 and had this issue with the Denon drivers after a windows update too for a long time. I then updated controller drivers from Serato website and it worked beautifully as expected every since.
I've had to try other 3rd party drivers and it never worked as good as the original Denon drivers.
Just my experience with this issue..
geposted Wed 26 Feb 20 @ 4:41 pm
It's the Denon drivers for the MC6000 Mk 1 that were discontinued in VirtualDJ.
The Denon drivers for the MC6000 MkII are fine afaik (I'm on a Mac).
geposted Wed 26 Feb 20 @ 4:45 pm
In Denon website they do have older drivers available for MC 6000 Mk series.
When on this site: Look for legacy Denon DJ products? Click here
https://www.denondj.com/downloads
Page Up to find your controller and you'll see at the bottom "click Here" for older driver downloads.
Good Luck...
Good Luck...
geposted Thu 27 Feb 20 @ 6:56 pm
