Topic: Play Count History Question
Just upgraded to a new laptop and I was wondering, if there anyway that I can update my play counts to show what my previous laptop was showing? I copied and transferred my Virtual DJ to the new computer, however I can't get it to show my play counts. Is this even a possibility?
Thanks
Kenny
geposted Fri 28 Feb 20 @ 5:32 am
JoeyKJPRO InfinityMember since 2008
If you copied your Drv C: vdj folder into the new laptop it should match. Try copping your database xml file from the old to the new to see if this will work, but before you do that make a backup copy of database in the new laptop or rename it before you swap it out.
geposted Fri 28 Feb 20 @ 7:27 am
Ok. Thanks
geposted Fri 28 Feb 20 @ 1:07 pm
