My MixTrac Pro 2 mixer is not functioning properly, it moves the sliders for pitch control randomly and is getting very annoying can anyone assist
geposted Fri 28 Feb 20 @ 4:26 pm
Fader bleed, eventually all cheap contact faders wear out, you could try electrical switch cleaner or compressed air to see if that fixes it.
Other thing it could be is a floating earth on the pcb but that would need opening the controller up and going at it with a soldering iron.
geposted Fri 28 Feb 20 @ 5:33 pm
