I've been spending the past couple days digging through the net to figure out if the Akai MPD 26 is compatible with VDJ but still cannot find a definite answer. I connect it via USB, go to my Preferences and scan for devices but it cannot find it.Any suggestions as to what I can try or if it is even compatible with VDJ?
Thanks,
Alex.
Thanks,
Alex.
geposted Fri 06 Mar 20 @ 2:58 pm
The list of supported controllers is in the wiki...
https://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Fri 06 Mar 20 @ 6:50 pm
It's not supported but it is midi, so you could write a definition file and a mapper file
geposted Fri 06 Mar 20 @ 7:25 pm
