Topic: Denon HD2500 no sound at chan 3-4
Hi
When i run vdj with my hd2500 i get no sound on deck 2 asio channel 3-4. If I patch and add deck 2 to channel 1-2, it works.
It has worked without problems before. Tested with two different computers.
geposted Sun 08 Mar 20 @ 12:54 pm
I had the same issue and it has to do with audio options. Find exclusive audio Access box should be checked yes
geposted Mon 02 Nov 20 @ 9:54 pm
geposted Mon 02 Nov 20 @ 11:00 pm
