Hi, can be a png file used in videoskin as a logo? If yes, how should this line in xml look like?
Thank you.
Thank you.
geposted Mon 09 Mar 20 @ 1:56 pm
Just click "edit" for a skin, or start from scratch creating a new one.
A skin has an image file and an xml file. For the logo, add it to the image file, then give the coordinates for this logo, in the xml, for example using a <visual> tag.
Can learn more here :
https://www.virtualdj.com/wiki/Modify%20a%20Skin.html
https://www.virtualdj.com/wiki/SkinSDK8.html
geposted Mon 09 Mar 20 @ 2:11 pm
I will try, thank you.
geposted Mon 09 Mar 20 @ 2:21 pm
