I've got a gig coming up and I really hope someone can help me figure this out ASAP.
I have the Echo effect turned on but the noise is not the echo effect I'm used to. It sounds like flanger. This happened when I was trying to use Flanger as my 2nd effect and I turned off the Flanger still the Echo is broken.
You can see in my settings there is no flanger turned on.
geposted Tue 10 Mar 20 @ 4:23 pm
Yeah pictures help with a sonic issue :P, perhaps you changed the echo beats length?
geposted Tue 10 Mar 20 @ 4:39 pm
