Topic: removing decimal BPM from plate display
DJ Abe GPRO InfinitySenior staffMember since 2019
Is there a way to get rid of the two trailing decimal bpm reading from the turntable display (or even to just remove one of the numbers?). I'm not talking about down where your music list is. I mean up on the turntable display.
Thanks.
And if you can't, can this be a feature?
geposted Wed 11 Mar 20 @ 6:39 pm
search your xml for, [there are 2 cases]
<text fontsize="30" color="textdeck" align="center" weight="bold" format="%Pbpmex"/>
replace with
<text fontsize="30" color="textdeck" align="center" weight="bold" format="`get_bpm & param_cast 'integer'`"/>
geposted Wed 11 Mar 20 @ 7:35 pm
replace with
I've searched and found no such parameter. Are you talking about the settings.XML? I don't see any other file on Mac.
geposted Tue 24 Mar 20 @ 3:46 pm
It's the xml of the skin you are using. You will need to remove it from the zip file then add it back again once modified.
geposted Tue 24 Mar 20 @ 3:52 pm
NicotuxHome userMember since 2014
For default skin, just go to settings -> interface and click on "Edit this skin" at top right
This will extract the skin and open the created folder
edit the xml file
Once done select "Default (edit)" skin in VDJ
geposted Tue 24 Mar 20 @ 4:58 pm
