Forum: Addons
Topic: Controller 2020 by DennYo - Page: 5
Denny DennYo wrote :
Version History 3.0.5
-Bugfix - the width of the right padbutton 2 on 2 deck middle extra corrected
Thank you very much for such an awesome new skin (2020) and for replying to, and addressing and fixing our concerns! :)
geposted Wed 15 Apr 20 @ 3:42 pm
AsTheDJPRO InfinityMember since 2008
goin.
geposted Thu 16 Apr 20 @ 12:33 am
Version History 3.0.6
-Bugfix - the Custom Buttons on toggle pad and cue area are visible, now
geposted Thu 16 Apr 20 @ 2:20 pm
Burn1PRO InfinityMember since 2009
DennYo
Thank you for the scripts much appreciated
DJBernieB
geposted Thu 16 Apr 20 @ 4:30 pm
Version History 3.0.7
-add- KEY menu like the original Skin
geposted Fri 17 Apr 20 @ 3:23 pm
labbedjPRO InfinityMember since 2013
Text goes over other text
geposted Sun 19 Apr 20 @ 4:15 am
The bottom of the letter g in reggaeton is alo cut off...
geposted Sun 19 Apr 20 @ 7:53 am
h
Hello joaolabbe,
you doesn't use the newest version. The size of textzone (artist and trackname) are correct since last update.
The correct size of the cuetext comes on the next update.
geposted Sun 19 Apr 20 @ 12:15 pm
My interfase reads:3.0.7. I thought it was the latest. I there a new one. I keep re-installing the skin to get the update.
h
Hello joaolabbe,
geposted Sun 19 Apr 20 @ 1:12 pm
3.0.7 is the newest online Version.
your screenshot is older than the 3.0.7
in the 3.0.7 is KEY setting feature on the Songinfo Area. show screenshot -->
geposted Sun 19 Apr 20 @ 2:14 pm
There's clearly an issue with the way the extensions area works in VDJ...as it doesn't work properly.
I can tell from the difference in the key display of the skin that I don't have the latest version, yet VDJ is not telling me there's a newer version.
geposted Sun 19 Apr 20 @ 3:37 pm
Exactly . There is no way of telling in what update you are at the moment but from my screen shot this is what I got:
geposted Sun 19 Apr 20 @ 9:21 pm
Version History 3.0.8
-Bugfix - Textsize of the Cue Buttons
-Bugfix - KEY move arrow in big deck Video was on the wrong position
-add - you can turn off the border arround the Song Infos Pitch/KEY/Gain/Rate ("Skin Button"/Deck Setup/Border SOng Infos)
geposted Mon 20 Apr 20 @ 4:40 am
hi
is the latest update aprooved yet ?
i only see in extensions & have in vdj 3.04
geposted Mon 20 Apr 20 @ 1:17 pm
romeodan wrote :
hi
At the moment is 3.0.7 aprooved.
geposted Mon 20 Apr 20 @ 1:24 pm
stlvsPRO InfinityMember since 2018
That orange color on the selected file and on the selected track at the browser area,is there a way to disable it?
geposted Mon 20 Apr 20 @ 1:26 pm
yes , but this is what is installed ..
maybe it is 3.07 but says 3.04 ?
geposted Mon 20 Apr 20 @ 1:31 pm
search in the skin.xml the row
<define color="browserliststripefocus" value="#C46A12"/>
In this row you can change the color.
There are two lines with this content, please change them.
when you found a good color please post the htmk #xxxxxx Code. I will change it for the future.
check this color: #587190
geposted Mon 20 Apr 20 @ 1:32 pm
Uninstall the skin and reinstall from the extention hub.
I have it doawnload just at this moment and i get the 3.0.7.
geposted Mon 20 Apr 20 @ 1:39 pm
you are right !
thanks !
geposted Mon 20 Apr 20 @ 1:42 pm
20%
