I am using a mixon 4 and when i use the cue button i can only hear the music coming out of one ear.On deck 1 its the left ear and on deck 2 its the right ear.How can i fix this?
geposted Thu 19 Mar 20 @ 12:55 am
Please read the setup guide...
https://www.virtualdj.com/manuals/hardware/reloop/mixon4/index.html
geposted Thu 19 Mar 20 @ 5:52 pm
Isn't the sound supposed to go into the ear?
geposted Thu 19 Mar 20 @ 11:35 pm
Yes both ears not one
geposted Fri 20 Mar 20 @ 2:37 am
depends if you like split headphones...
geposted Fri 20 Mar 20 @ 2:48 am
Did you fix it? Search for splitHeadphones in settings Thats most likely it.
Just click the Mixon 4 button in sound settings to make sure you are using correct settings also
https://www.virtualdj.com/manuals/hardware/reloop/mixon4/setup.html
geposted Fri 20 Mar 20 @ 7:15 pm
