Topic: Can't Connect to Shoutcast server.
TantrixPRO InfinityMember since 2013
Ok I have VDJ 2020 (b5504) running on an HP Envy 3.0ghz and 8gb DDR I am a Pro User. I have a paid shoutcast account that is served by shoutcast. I am trying to broadcast video using VDJs "broadcast" tab. See image below:
Every time I try to connect it says "invalid password"...even though the password is correct. I want to be able to stream video through Shoutcast. I am able to broadcast through Facebook but I keep getting muted (copyright).
Any help would be awesome.
geposted Thu 19 Mar 20 @ 9:59 pm
shoutcast doesn't do video
geposted Thu 19 Mar 20 @ 10:30 pm
It doesn't matter because it still does not connect and I get the same error.
geposted Thu 19 Mar 20 @ 10:42 pm
Sure the server URL is correct? likely is a /youraccount/ at end ...
http://masterv2.shoutcast.com:8000/ is forbidden to access.. usually indicative of there being "mount" (streamid) parts needed to be added to the URL
And given Shoutcast likely have more customers than one, I would think each have their unique one perhaps. Unless "masterv2" is your account login, and they give each user their own sub-domain
(but this all depends on the server provider. Look at the settings suggested from them)
I would think the url to use should be something along masterv2.shoutcast.com/some-stream-ID
https://help.shoutcast.com/hc/en-us/articles/115002825753-Get-your-station-up-and-running-in-a-few-minutes
geposted Thu 19 Mar 20 @ 10:54 pm
