It looks like the new swap_decks feature only swaps the audio(files), position and play status, and then the gain levels
Would it be possible to also add options to swap other deck elements?
Like for instance
- current eq levels
- current deck volume levels
- current filter levels (and thereby also color fx levels)
Like for instance
- current eq levels
geposted Sun 22 Mar 20 @ 10:17 am
Since the primary use is probably scratchers, chances are pretty high that an external mixer or controller is used.
That means swapping eq and filter would make all the knobs on the mixer not reflect the actual position, so I'm not sure if this is practical
geposted Sun 22 Mar 20 @ 10:33 am
"As is" allows for interesting 1 button toggle from one eq/fx set up to another,
from how I read what you're after Klaus, perhaps something like this is what you're thinking [this is ideal running 4 decks on a two deck skin]
invert_deck & deck 1 select ? deck 3 select : deck 2 select ? deck 4 select : deck 3 select ? deck 1 select : deck 4 select ? deck 2 select :
geposted Mon 23 Mar 20 @ 1:46 am
