Topic: Newest Update Issue
I just turned on my VDJ and it said there was a new update. I went ahead and updated and now VDJ will not open. I am using a MacBook. Is there any way to back out the update?
geposted Tue 24 Mar 20 @ 10:05 pm
try rename settings.xml in /documents/virtualdj/ ... (resets back to factory default when doing so)
Opens then?
Alternatively, try just run the installer again from here : https://virtualdj.com/download/
(just run it without uninstalling anything first... ).
geposted Tue 24 Mar 20 @ 10:07 pm
Opens then?
Yes, I re-installed but it still does not open.
I am running a MacBook. Not sure where the Documents thing is at
geposted Tue 24 Mar 20 @ 10:13 pm
Wait...found the settings.xml
Looks like it might have worked. It opened. Now I have to test it.
geposted Tue 24 Mar 20 @ 10:17 pm
Might have just been skin, or a setting, that got stuck
As long as it works again now, all should be good ;-)
geposted Tue 24 Mar 20 @ 10:24 pm
