is there a way to remap the roll button on the Pioneer DDJ-SZ2 to make it do FX FADE
geposted Thu 26 Mar 20 @ 1:53 am
probably depends what you mean by FX FADE
the slid3r pad page can show you what is possible [turn an fx on for a beat duration and have a slider move from point a to point b over that duration.]
http://www.virtualdj.com/forums/229519/addons/Slid3R.html?page=1
the script on that thing is crazy, but doing a known fx for a known duration with the slider values pre decided, pretty easy for me
and my rates are reasonable.
geposted Thu 26 Mar 20 @ 2:05 am
We would like to put this as a button to get to faster in place of the roll button
geposted Thu 26 Mar 20 @ 2:40 am
Understand this is just an example but I'm sure that there's a way to map almost any button on this Control
geposted Thu 26 Mar 20 @ 3:00 am
oh so not an actual fx action then, you just want to call the padpage.
where's the difficulty? Have you even looked at it? you're literally changing one thing, inserting the pad page name you want in place of the one you don't want.
pad_page 'loop roll'
to
pad_page 'WHATEVER'
to
pad_page 'WHATEVER'
geposted Thu 26 Mar 20 @ 3:08 am
So I have a DJ that will never use the roll function on his controller he would like to make that button pull up FX functions on his pads
geposted Thu 26 Mar 20 @ 3:19 am
locodog wrote :
you just want to call the padpage..
pad_page 'loop roll' to pad_page 'WHATEVER'
I mapped pad_page 'loop roll' to keyboard however when PADS panel(favorites) is checked 'loop roll does not shown up within the visible pad page only the beats. What script can I use to so it shows up among the 4 pad page?
geposted Thu 26 Mar 20 @ 12:58 pm
Bump
anyone?
anyone?
geposted Fri 27 Mar 20 @ 1:19 am
Just change the entry for PAD_MODE_ROLL to pad_page 'fx fade'
geposted Fri 27 Mar 20 @ 1:31 am
Thank You that was what I was looking for
geposted Fri 27 Mar 20 @ 2:18 am
