I can only get sound from my laptop and not through the speaker?
geposted Sun 29 Mar 20 @ 5:42 am
You are using a controller then I suppose? with speakers connected?
If so, what controller are you using?
And generally the quick way to set sound to use controller the default way, just open sound settings in VirtualDJ, and click the button with your controller name on there :)
geposted Sun 29 Mar 20 @ 2:14 pm
