Topic: Mi controladora pionner RZX
Cada que quiero bajar la interfaz me dice que vaya directo a la pagina de virtual dj y es donde estoy con peras y manzanas me pueden ayudar para descargar ese skin, mi licencia es Pro cul es el Problema Gracias. alguin que me pueda ayudar a solo darle descargar asi de simple.
geposted Sun 29 Mar 20 @ 10:12 pm
Pioneer RZX skin is ONLY for use on Pioneer DDJ-RZX controller screens
It's not a skin for main VirtualDJ application
i've been trying to find a screens add on for the pioneer ddj rzx. But i can't find it. How can i get the screens of my rzx to work properly with virtual dj 8.5. My license is PRO (for 30 days)
It's here
https://www.virtualdj.com/plugins/index.html?addonid=80833
....but notice it says "direct link only" which I believe means it should download automatically when VDJ detects the DDJ-RZX.
It's alos likely to be a hidden skin, which means you won't see it in the skin list inside VDJ.
