Topic: Mouse scratch in build 5619 is bad
in b5541 is normal. WTF ?
geposted Wed 01 Apr 20 @ 1:23 pm
Hmm... I can't tell the difference between scratching with the mouse in b5619 and b5504 (current public version)
Are you doing it on the scratch pane waveform?
geposted Wed 01 Apr 20 @ 2:24 pm
in b5630 also mouse scratch on jog not sharp when driving slowly.
this is not very noticeable, but the differences are felt after 5541.
geposted Tue 07 Apr 20 @ 1:01 am
5647 also and in controller
return normal scratch!
geposted Sat 11 Apr 20 @ 3:10 am
Well maybe it does seem a bit "swimmy" - a bit soft. Not very sharp.
Not that I ever scratch with my mouse... I didn't go back to an older build to compare.
geposted Sat 11 Apr 20 @ 6:52 am
solve the problem!
geposted Sun 12 Apr 20 @ 3:15 am
Use b5541!
geposted Sun 12 Apr 20 @ 7:11 am
Why did they make it worse?
geposted Mon 13 Apr 20 @ 3:26 am
