I have a Denon HC4500 Midi controller and it used to work with the ASIO drivers no problem. But now I can't seem to use it no more it only lets me use the WASAPI Drivers.
I have been into the sound settings and changed it to 16 bit CD quality and I get sound from Deck A but not deck B
When I try to change the audio settings on the HC4500 in windows to use 3.1. I get an error saying that it's not supported by the device.
Can anyone help please. I would like to get this controller working as it did before.
If I use Virtual DJ 7 and the asio drivers with that it works fine.
thanks John
Thanks
John
thanks John
Thanks
John
geposted Wed 01 Apr 20 @ 2:36 pm
I have managed to fix the problem myself thanks anyway.
geposted Wed 01 Apr 20 @ 3:34 pm
