Having a issue with transport mode not responding from the mixer
Can only get it through pad page dropdown
geposted Fri 03 Apr 20 @ 5:26 pm
Look here , https://www.virtualdj.com/manuals/hardware/mixars/quattro/top.html
And see if you can get it working as intended
geposted Fri 03 Apr 20 @ 6:20 pm
Yes all modes work as intended except transport mode
When holding shift+cues it defaults back to cue mode
geposted Fri 03 Apr 20 @ 6:30 pm
Does this happen on both sides of the mixer ?
geposted Fri 03 Apr 20 @ 9:00 pm
Yes
geposted Sat 04 Apr 20 @ 4:41 pm
Strange. Are you running latest firmware ?
geposted Sat 04 Apr 20 @ 9:37 pm
We have found the issue and it will be fixed in next update!
geposted Sun 05 Apr 20 @ 4:00 pm
Thanks!
geposted Sun 05 Apr 20 @ 4:39 pm
Mine will be here tomorrow!! Can’t wait to try it out.
How’s everything going with yours so far??
geposted Sun 12 Apr 20 @ 1:57 pm
Loving it! stock x-fader is not as bad as advertised,did swap it out for the mixar replacement tho.
My biggest issue was waiting for the vdj map!
Built in effects are hit or miss.
Now just need to get a couple more tt's!
geposted Mon 13 Apr 20 @ 1:17 pm
Just hooked it up and man I’m really liking this thing!! Yes the fxs aren’t the best but I’ll get used to it plus I don’t really use many anyways.
Other then that my pitch up/down buttons are reversed, can you confirm this please?
geposted Mon 13 Apr 20 @ 11:53 pm
Sorted?
Away from my unit till the weekend
geposted Tue 14 Apr 20 @ 3:40 pm
Yeah I’m sureness I can fix it, just a matter of switching them around.
geposted Tue 14 Apr 20 @ 6:48 pm
