Topic: VCI 380 Set up JOG SCROLL
DJ JLptyPRO SubscriberMember since 2019
hello community greetings to all and blessings, I am currently using the VCI 380 controller and I have a little problem I hope you can help me thanks!!
1. the problem I have is that: I have to press the JOG SCROLL next to load A at the same time to load a song, on the deck on the left or deck on the right.
the truth is I work very uncomfortable and it is very slow to press the keys at the same time.
- Is it possible to configure to only use load A or load B? for LOAD de music on the deks like a normal in others controllers!!
*I need to configure to stop using and press the JOG SCROLL key, since when the JOG is active, the scratch is unconfigured.
2. Is it possible to change the mark of the song already played? put some specific color? like serato he put your music played with blue color!
3.When I finish setting up my virtual dj, how do I save it. since I have occasions when I turn off the computer and return to use it appears normal and I lose everything configured. why is that happening?
at the moment i use windows not mac, my virtual dj is legal is not crack!
geposted Sat 04 Apr 20 @ 10:14 pm
is donde
geposted Tue 07 Apr 20 @ 8:01 pm
