Maybe asking for a pastboard on virtualdj.com would be a good idea for skins and pads and plugins devs would be nice
geposted Mon 06 Apr 20 @ 7:25 pm
thanks for uploading it to pastebin
geposted Mon 06 Apr 20 @ 7:34 pm
locodog : I know that with a script it can't be done, they told me, but I managed to carry out the sequence with the script no more, I put it as the last point to save, play and others because I know it's the last step
geposted Mon 06 Apr 20 @ 7:41 pm
it's not the last step, it's the first consideration. Everything else depends on it. You could be a talented painter but without a canvas nothing happens.
geposted Mon 06 Apr 20 @ 8:03 pm
I understand, first I need to save the sequence and how do I create the dll plugin with C ++? Because I do need the plugin, yes or yes.
geposted Mon 06 Apr 20 @ 8:19 pm
Here you go..
<?xml version="1.0" encoding="UTF-8"?>
<page name="Secuenciador">
<pad1 name="`get_sample_name 1`">sampler_play_stutter 1 & var '1'? cycle 'c1' 17 & cycle 'c1' 1 ? set 'contador1' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's' & sampler_play_stutter 1 : cycle 'c1' 2 ? set 'contador2' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's2' & sampler_play_stutter 1 : cycle 'c1' 3 ? set 'contador3' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's3' & sampler_play_stutter 1 : cycle 'c1' 4 ? set 'contador4' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's4' & sampler_play_stutter 1 : cycle 'c1' 5 ? set 'contador5' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's5' & sampler_play_stutter 1 : cycle 'c1' 6 ? set 'contador6' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's6' & sampler_play_stutter 1 : cycle 'c1' 7 ? set 'contador7' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's7' & sampler_play_stutter 1 : cycle 'c1' 8 ? set 'contador8' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's8' & sampler_play_stutter 1 : cycle 'c1' 9 ? set 'contador9' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's9' & sampler_play_stutter 1 : cycle 'c1' 10 ? set 'contador10' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's10' & sampler_play_stutter 1 : cycle 'c1' 11 ? set 'contador11' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's11' & sampler_play_stutter 1 : cycle 'c1' 12 ? set 'contador12' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's12' & sampler_play_stutter 1 : cycle 'c1' 13 ? set 'contador13' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's13' & sampler_play_stutter 1 : cycle 'c1' 14 ? set 'contador14' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's14' & sampler_play_stutter 1 : cycle 'c1' 15 ? set 'contador15' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's15' & sampler_play_stutter 1 : cycle 'c1' 16 ? set 'contador16' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's16' & sampler_play_stutter 1 : nothing : nothing</pad1>
<pad2 name="`get_sample_name 2`">sampler_play_stutter 2 & var '1'? cycle 'c2' 17 & cycle 'c2' 1 ? set 'contador17' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's17' & sampler_play_stutter 2 : cycle 'c2' 2 ? set 'contador18' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's18' & sampler_play_stutter 2 : cycle 'c2' 3 ? set 'contador19' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's19' & sampler_play_stutter 2 : cycle 'c2' 4 ? set 'contador20' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's20' & sampler_play_stutter 2 : cycle 'c2' 5 ? set 'contador21' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's21' & sampler_play_stutter 2 : cycle 'c2' 6 ? set 'contador22' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's22' & sampler_play_stutter 2 : cycle 'c2' 7 ? set 'contador23' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's23' & sampler_play_stutter 2 : cycle 'c2' 8 ? set 'contador24' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's24' & sampler_play_stutter 2 : cycle 'c2' 9 ? set 'contador25' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's25' & sampler_play_stutter 2 : cycle 'c2' 10 ? set 'contador26' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's26' & sampler_play_stutter 2 : cycle 'c2' 11 ? set 'contador27' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's27' & sampler_play_stutter 2 : cycle 'c2' 12 ? set 'contador28' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's28' & sampler_play_stutter 2 : cycle 'c2' 13 ? set 'contador29' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's29' & sampler_play_stutter 2 : cycle 'c2' 14 ? set 'contador30' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's30' & sampler_play_stutter 2 : cycle 'c2' 15 ? set 'contador31' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's31' & sampler_play_stutter 2 : cycle 'c2' 16 ? set 'contador32' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's32' & sampler_play_stutter 2 : nothing : nothing</pad2>
<pad3 name="`get_sample_name 3`">sampler_play_stutter 3 &var '1'? cycle 'c3' 17 & cycle 'c3' 1 ? set 'contador33' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's33' & sampler_play_stutter 3 : cycle 'c3' 2 ? set 'contador34' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's34' & sampler_play_stutter 3 : cycle 'c3' 3 ? set 'contador35' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's35' & sampler_play_stutter 3 : cycle 'c3' 4 ? set 'contador36' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's36' & sampler_play_stutter 3 : cycle 'c3' 5 ? set 'contador37' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's37' & sampler_play_stutter 3 : cycle 'c3' 6 ? set 'contador38' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's38' & sampler_play_stutter 3 : cycle 'c3' 7 ? set 'contador39' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's39' & sampler_play_stutter 3 : cycle 'c3' 8 ? set 'contador40' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's40' & sampler_play_stutter 3 : cycle 'c3' 9 ? set 'contador41' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's41' & sampler_play_stutter 3 : cycle 'c3' 10 ? set 'contador42' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's42' & sampler_play_stutter 3 : cycle 'c3' 11 ? set 'contador43' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's43' & sampler_play_stutter 3 : cycle 'c3' 12 ? set 'contador44' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's44' & sampler_play_stutter 3 : cycle 'c3' 13 ? set 'contador45' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's45' & sampler_play_stutter 3 : cycle 'c3' 14 ? set 'contador46' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's46' & sampler_play_stutter 3 : cycle 'c3' 15 ? set 'contador47' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's47' & sampler_play_stutter 3 : cycle 'c3' 16 ? set 'contador48' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's48' & sampler_play_stutter 3 : nothing : nothing</pad3>
<pad4 name="`get_sample_name 4`">sampler_play_stutter 4 & var '1'? cycle 'c4' 17 & cycle 'c4' 1 ? set 'contador49' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's49' & sampler_play_stutter 4 : cycle 'c4' 2 ? set 'contador50' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's50' & sampler_play_stutter 4 : cycle 'c4' 3 ? set 'contador51' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's51' & sampler_play_stutter 4 : cycle 'c4' 4 ? set 'contador52' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's52' & sampler_play_stutter 4 : cycle 'c4' 5 ? set 'contador53' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's53' & sampler_play_stutter 4 : cycle 'c4' 6 ? set 'contador54' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's54' & sampler_play_stutter 4 : cycle 'c4' 7 ? set 'contador55' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's55' & sampler_play_stutter 4 : cycle 'c4' 8 ? set 'contador56' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's56' & sampler_play_stutter 4 : cycle 'c4' 9 ? set 'contador57' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's57' & sampler_play_stutter 4 : cycle 'c4' 10 ? set 'contador58' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's58' & sampler_play_stutter 4 : cycle 'c4' 11 ? set 'contador59' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's59' & sampler_play_stutter 4 : cycle 'c4' 12 ? set 'contador60' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's60' & sampler_play_stutter 4 : cycle 'c4' 13 ? set 'contador61' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's61' & sampler_play_stutter 4 : cycle 'c4' 14 ? set 'contador62' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's62' & sampler_play_stutter 4 : cycle 'c4' 15 ? set 'contador63' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's63' & sampler_play_stutter 4 : cycle 'c4' 16 ? set 'contador64' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's64' & sampler_play_stutter 4 : nothing : nothing</pad4>
<pad5 name="`get_sample_name 5`">sampler_play_stutter 5 & var '1'? cycle 'c5' 17 & cycle 'c5' 1 ? set 'contador65' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's65' & sampler_play_stutter 5 : cycle 'c5' 2 ? set 'contador66' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's66' & sampler_play_stutter 5 : cycle 'c5' 3 ? set 'contador67' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's67' & sampler_play_stutter 5 : cycle 'c5' 4 ? set 'contador68' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's68' & sampler_play_stutter 5 : cycle 'c5' 5 ? set 'contador69' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's69' & sampler_play_stutter 5 : cycle 'c5' 6 ? set 'contador70' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's70' & sampler_play_stutter 5 : cycle 'c5' 7 ? set 'contador71' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's71' & sampler_play_stutter 5 : cycle 'c5' 8 ? set 'contador72' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's72' & sampler_play_stutter 5 : cycle 'c5' 9 ? set 'contador73' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's73' & sampler_play_stutter 5 : cycle 'c5' 10 ? set 'contador74' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's74' & sampler_play_stutter 5 : cycle 'c5' 11 ? set 'contador75' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's75' & sampler_play_stutter 5 : cycle 'c5' 12 ? set 'contador76' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's76' & sampler_play_stutter 5 : cycle 'c5' 13 ? set 'contador77' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's77' & sampler_play_stutter 5 : cycle 'c5' 14 ? set 'contador78' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's78' & sampler_play_stutter 5 : cycle 'c5' 15 ? set 'contador79' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's79' & sampler_play_stutter 5 : cycle 'c5' 16 ? set 'contador80' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's80' & sampler_play_stutter 5 : nothing : nothing</pad5>
<pad6 name="`get_sample_name 6`">sampler_play_stutter 6 & var '1'? cycle 'c6' 17 & cycle 'c6' 1 ? set 'contador81' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's81' & sampler_play_stutter 6 : cycle 'c6' 2 ? set 'contador82' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's82' & sampler_play_stutter 6 : cycle 'c6' 3 ? set 'contador83' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's83' & sampler_play_stutter 6 : cycle 'c6' 4 ? set 'contador84' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's84' & sampler_play_stutter 6 : cycle 'c6' 5 ? set 'contador85' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's85' & sampler_play_stutter 6 : cycle 'c6' 6 ? set 'contador86' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's86' & sampler_play_stutter 6 : cycle 'c6' 7 ? set 'contador87' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's87' & sampler_play_stutter 6 : cycle 'c6' 8 ? set 'contador88' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's88' & sampler_play_stutter 6 : cycle 'c6' 9 ? set 'contador89' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's89' & sampler_play_stutter 6 : cycle 'c6' 10 ? set 'contador90' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's90' & sampler_play_stutter 6 : cycle 'c6' 11 ? set 'contador91' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's91' & sampler_play_stutter 6 : cycle 'c6' 12 ? set 'contador92' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's92' & sampler_play_stutter 6 : cycle 'c6' 13 ? set 'contador93' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's93' & sampler_play_stutter 6 : cycle 'c6' 14 ? set 'contador94' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's94' & sampler_play_stutter 6 : cycle 'c6' 15 ? set 'contador95' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's95' & sampler_play_stutter 6 : cycle 'c6' 16 ? set 'contador96' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's96' & sampler_play_stutter 6 : nothing : nothing</pad6>
<pad7 name="`get_sample_name 7`">sampler_play_stutter 7 & var '1'? cycle 'c7' 17 & cycle 'c7' 1 ? set 'contador97' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's97' & sampler_play_stutter 7 : cycle 'c7' 2 ? set 'contador98' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's98' & sampler_play_stutter 7 : cycle 'c7' 3 ? set 'contador99' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's99' & sampler_play_stutter 7 : cycle 'c7' 4 ? set 'contador100' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's100' & sampler_play_stutter 7 : cycle 'c7' 5 ? set 'contador101' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's101' & sampler_play_stutter 7 : cycle 'c7' 6 ? set 'contador102' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's102' & sampler_play_stutter 7 : cycle 'c7' 7 ? set 'contador103' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's103' & sampler_play_stutter 7 : cycle 'c7' 8 ? set 'contador104' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's104' & sampler_play_stutter 7 : cycle 'c7' 9 ? set 'contador105' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's105' & sampler_play_stutter 7 : cycle 'c7' 10 ? set 'contador106' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's106' & sampler_play_stutter 7 : cycle 'c7' 11 ? set 'contador107' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's107' & sampler_play_stutter 7 : cycle 'c7' 12 ? set 'contador108' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's108' & sampler_play_stutter 7 : cycle 'c7' 13 ? set 'contador109' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's109' & sampler_play_stutter 7 : cycle 'c7' 14 ? set 'contador110' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's110' & sampler_play_stutter 7 : cycle 'c7' 15 ? set 'contador111' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's111' & sampler_play_stutter 7 : cycle 'c7' 16 ? set 'contador112' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's112' & sampler_play_stutter 7 : nothing : nothing</pad7>
<pad8 name="`get_sample_name 8`">sampler_play_stutter 8 & var '1'? cycle 'c8' 17 & cycle 'c8' 1 ? set 'contador113' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's113' & sampler_play_stutter 8 : cycle 'c8' 2 ? set 'contador114' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's114' & sampler_play_stutter 8 : cycle 'c8' 3 ? set 'contador115' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's115' & sampler_play_stutter 8 : cycle 'c8' 4 ? set 'contador116' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's116' & sampler_play_stutter 8 : cycle 'c8' 5 ? set 'contador117' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's117' & sampler_play_stutter 8 : cycle 'c8' 6 ? set 'contador118' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's118' & sampler_play_stutter 8 : cycle 'c8' 7 ? set 'contador119' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's119' & sampler_play_stutter 8 : cycle 'c8' 8 ? set 'contador120' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's120' & sampler_play_stutter 8 : cycle 'c8' 9 ? set 'contador121' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's121' & sampler_play_stutter 8 : cycle 'c8' 10 ? set 'contador122' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's122' & sampler_play_stutter 8 : cycle 'c8' 11 ? set 'contador123' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's123' & sampler_play_stutter 8 : cycle 'c8' 12 ? set 'contador124' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's124' & sampler_play_stutter 8 : cycle 'c8' 13 ? set 'contador125' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's125' & sampler_play_stutter 8 : cycle 'c8' 14 ? set 'contador126' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's126' & sampler_play_stutter 8 : cycle 'c8' 15 ? set 'contador127' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's127' & sampler_play_stutter 8 : cycle 'c8' 16 ? set 'contador128' `param_multiply "get_bpm & param_1_x" 960000` & param_cast 'ms' & repeat_start 's128' & sampler_play_stutter 8 : nothing : nothing</pad8>
<shift_pad1 />
</page>
geposted Mon 06 Apr 20 @ 8:22 pm
And what do I do with it?
geposted Mon 06 Apr 20 @ 8:27 pm
Was just instead of the upload to Mega ;-)
geposted Mon 06 Apr 20 @ 8:29 pm
OK thank you
geposted Mon 06 Apr 20 @ 8:31 pm
Support staff wrote :
Here you go...
Sorry for resurrecting this post, I tried the commands and they are valid but unfortunately in the absence of a virtual dj internal sequencer they can be fine even if I should also try to return the values for 16 and 32 pads.
But my question is if there is a command to add to synchronize/quantize the pressed pads with the virtual dj grid and possibly also with the tempo/pitch change otherwise it won't be easy to play, for example, a loop of single drum kits that time perfectly with the song being played. Is there a solution? Thank you
geposted Wed 01 Feb 23 @ 2:44 pm
