Hi! I'm having trouble broadcasting with virtualDJ (both version 2018 and 2020).
I log in to my account at VirtualDJ and press "START BROADCAST", but below I still have "You must be logged in for broadcasting. Log in here", and when I press the "Log in here" nothing happens.
Does anyone know how to solve this problem?
Thank you,
Matan.
Thank you,
Matan.
geposted Sun 05 Apr 20 @ 1:17 pm
Try log out of VirtualDJ inside the software, then log back in.. Works then?
Had a user with similar post a few weeks ago. This fixed that.
geposted Sun 05 Apr 20 @ 3:45 pm
Hey, I've tried that several times. Still doesn't work. Also tried it from another guy's computer and with his user and password and still the same problem.
geposted Sun 05 Apr 20 @ 4:44 pm
Try again now, i made a little change to account.
If it works now, then there was a small little bug, that we'll fix ;-)
geposted Sun 05 Apr 20 @ 5:02 pm
wow!!! that problem really vanished!
now when I press on the link it gives the following error message:
Ups! Failed to connect to the DJs broadcast.
This broadcast is not reachable. Either the DJs computer has not open port for incoming connections, or the DJ has already ended the broadcast.
The DJ might need to open up port 8000 in firewall to be reachable for incoming connections
what do I need to do now?
geposted Sun 05 Apr 20 @ 8:48 pm
See here :
https://www.virtualdj.com/wiki/open%20port%20for%20direct%20broadcast.html ;-)
geposted Sun 05 Apr 20 @ 8:54 pm
Thanks so much!!
geposted Sun 05 Apr 20 @ 9:07 pm
