Topic: BROADCAST LIVE
no sound coming through the stream and everything setup correctly cause the link is green, please help
geposted Tue 07 Apr 20 @ 8:54 pm
geposted Tue 07 Apr 20 @ 9:54 pm
not using a mixer just using VDJ thats it
geposted Tue 07 Apr 20 @ 10:07 pm
Where are you broadcasting to? And what is your sounds settings?
geposted Tue 07 Apr 20 @ 10:33 pm
done this plenty of times before like this and it's worked fine
geposted Wed 08 Apr 20 @ 6:09 am
How did you "test" if there was no sound?
If you checked on your own computer, and only have one PC sound card available, it may be that its already in use (in VirtualDJ), it can be the browser can not play same time (since sound card is already in use) (unless you disable "exclusiveaudio")
Try check if all is good on your phone for example ;-)
geposted Wed 08 Apr 20 @ 5:30 pm
by sharing the link with a family member and my wife even tried on her phone and still no sound
and the "exclusiveaudio" is already set to yes
geposted Thu 09 Apr 20 @ 8:26 am
