Topic: OBS STUDIO WITH VIRTUAL DJ
Need help please trying to set up virtual dj 2020 with obs studio to broadcasts using Band lab Thanks
geposted Thu 09 Apr 20 @ 6:36 pm
You can broadcast directly from VirtualDJ to Bandlab, you dont need any 3rd party software ;-)
Just put the streamkey, server etc in VirtualDJ video broadcast settings
geposted Thu 09 Apr 20 @ 7:13 pm
If you rather want to use OBS i think you can just use "Capture Window", and use that to capture the video preview window in VirtualDJ
(+ add correct audio settings)
Been a while since i tried OBS but look at video below
geposted Thu 09 Apr 20 @ 7:21 pm
MANY THANKS FOR YOUR HELP
geposted Thu 09 Apr 20 @ 7:29 pm
Hola, quise hacer lo de OBS. pero al conectar mi controlador no sale el audio!!
geposted Mon 13 Apr 20 @ 7:47 pm
Hi there,
Stream via OBS
is it Possible to use the Video "Master out" instead of the whole decks without Freeze?
It works, but when i pick up tracks or use the search bar than the Video Signal Freeze. After that is it Impossible to bring the signal back without rebooting both Sytems, OBS & VDJ.
I Like the Video Master out cause you can see all actions direkt. But i want to put in the cam and some other Stuff to the Mainscreen.
geposted Mon 08 Jun 20 @ 8:27 am
djblazPRO InfinityMember since 2007
geposted Sat 19 Dec 20 @ 11:53 pm
freppaPRO InfinityMember since 2002
geposted Sun 20 Dec 20 @ 8:07 am
