Hi,
When the "Delete" option is selected after right-clicking on a Playlist, there is no pop-up message to confirm the intention to delete. This can lead to Playlists being accidentally deleted. Which I have just done.
Can this be addressed?
Thanks
Thanks
geposted Fri 10 Apr 20 @ 3:35 pm
The playlist is in your computer's recycle bin.
If you want to turn the confirmation back on, you can do so from the recycle bin properties:
https://www.tenforums.com/tutorials/32772-turn-off-recycle-bin-delete-confirmation-windows-10-a.html
geposted Fri 10 Apr 20 @ 4:09 pm
...ohhhh. Thank you! I just wish I had read this before rebuilding said playlist! 😭
geposted Fri 10 Apr 20 @ 5:39 pm
Helpful hint: Make regular backups of your VDJ folder, then you can restore things if you get careless again.
geposted Fri 10 Apr 20 @ 6:32 pm
